Partlist
Exported from ampliMos_06_masse.brd at 16/11/2003 23:38:31
EAGLE Version 4.01 Copyright (c) 1988-2001 CadSoft
Part     Value          Package  Library  Position (inch)       Orientation
C1       100u           E2,5-7   rcl      (1.875 1.0875)        R270
C2       10u            E2,5-6   rcl      (4.0875 1.3625)       R180
C3       47p            C050-024X044 rcl      (1.7125 0.9375)       R270
C4       2p2            C050-024X044 rcl      (0.9625 1.075)        R0
C5       *47p           C050-024X044 rcl      (2.55 2.4375)         R90
C6       *100p          C050-024X044 rcl      (1.925 2.625)         R270
C7       100n           C050-025X075 rcl      (3.6625 1.475)        R180
C8       100n           C050-025X075 rcl      (-0.4125 1.55)        R90
C9       470u           EB18D_SANYO rcl      (-0.4 3.3875)         R0
C10      470u           EB18D_SANYO rcl      (3.7625 1.925)        R90
C11      2.2u           C275-134X316 rcl      (4.3875 2.2)          R90
C12      2.2u           C275-134X316 rcl      (-0.55 2.375)         R270
C13      10n            C050-025X075 rcl      (0.5 2.1875)          R180
D1       1N4148         DO35-10  diode    (1.35 2.0375)         R180
D2       BZX55_8v2      DO35Z10  diode    (0.95 1.9)            R0
D3       1N4148         DO35-10  diode    (2.0625 1.175)        R270
D4       1N4148         DO35-10  diode    (2.1625 1.175)        R90
D5       1N4148         DO35-10  diode    (-0.0125 2.725)       R180
D6       1N4148         DO35-10  diode    (0.4375 1.7125)       R180
D7       BZX55_8v2      DO35Z10  diode    (0.6875 1.5125)       R270
H1       HP+            3,0-PAD-SQUARE holes    (2.25 3)              R0
H2       +40V           2,8-PAD-SQUARE holes    (3.2375 1.5375)       R0
H3       MASSE          2,8-PAD-SQUARE holes    (2.775 1.5375)        R0
H4       -40V           2,8-PAD-SQUARE holes    (-0.6625 1.5)         R0
H5       HP-            2,8-PAD-SQUARE holes    (2.425 1.5375)        R0
INPUT    1_RCA_2"       1_RCA_2  seb2     (4.2625 1.5625)       R270
JP1                     1X02     pinhead  (2.1375 3.575)        R0
JP2                     1X02     pinhead  (2.3625 3.575)        R180
JP3                     JP1      jumper   (3.9375 1.1875)       R270
R1       2K2            0207/10  rcl      (3.5875 1.1875)       R180
R2       2K2            0207/10  rcl      (2.6375 0.9875)       R270
R3       33K            0207/10  rcl      (3.0875 0.9875)       R90
R4       33K            0207/10  rcl      (0.9375 1.1625)       R180
R5       1K             0207/10  rcl      (1.4125 1.1375)       R180
R6       1K             0207/10  rcl      (2.1625 2.1875)       R90
R7       1K8            0207/10  rcl      (2.0625 1.8875)       R90
R8       4K7            0207/10  rcl      (2.1625 1.6875)       R90
R9       1K             0207/10  rcl      (1.4 1.525)           R180
R10      1K             0207/10  rcl      (1.2125 2.1375)       R180
R11      4K7            0207/10  rcl      (1.5125 1.95)         R180
R12      7K5            0207/10  rcl      (1.0625 1.625)        R180
R13      3K3            0207/10  rcl      (1.4125 0.85)         R0
R14      3K3            0207/10  rcl      (1.4125 1.2375)       R0
R15      1K             0309/12  rcl      (0.9875 3.1375)       R270
R16      1K             0309/12  rcl      (3.475 3.1375)        R270
R17      220            0207/10  rcl      (3.2625 3.0125)       R90
R18      220            0207/10  rcl      (3.3625 3.0125)       R90
R19      220            0207/10  rcl      (1.3 3.0125)          R90
R20      220            0207/10  rcl      (1.3875 3.0125)       R90
R21                     0309/12  rcl      (2.6875 3.25)         R90
R22                     0309/12  rcl      (2.8375 3.25)         R90
R23                     0309/12  rcl      (2.9875 3.25)         R90
R24                     0309/12  rcl      (3.1375 3.25)         R90
R25                     0309/12  rcl      (3.7625 3.25)         R90
R26                     0309/12  rcl      (3.9125 3.25)         R90
R27                     0309/12  rcl      (4.0625 3.25)         R90
R28                     0309/12  rcl      (4.2125 3.25)         R90
R29                     0309/12  rcl      (1.5125 3.25)         R270
R30                     0309/12  rcl      (1.6625 3.25)         R270
R31                     0309/12  rcl      (1.8125 3.25)         R270
R32                     0309/12  rcl      (1.9625 3.25)         R270
R33                     0309/12  rcl      (0.85 3.25)           R270
R34                     0309/12  rcl      (0.7 3.25)            R270
R35                     0309/12  rcl      (0.55 3.25)           R270
R36                     0309/12  rcl      (0.4 3.25)            R270
R37      100            0309/12  rcl      (0.225 3.1375)        R90
R38      100            0309/12  rcl      (1.1875 3.1375)       R90
R39      100            0309/12  rcl      (3.6125 3.1375)       R90
R40      100            0309/12  rcl      (2.5375 3.1375)       R90
R41      3K3            0207/10  rcl      (-0.05 1.6125)        R180
R42      33K            0207/10  rcl      (0.1125 2.3625)       R180
R43      4K7            0207/10  rcl      (-0.125 2)            R270
R44      4K7            0207/10  rcl      (-0.05 1.7125)        R180
R45      100            0207/10  rcl      (0.1125 2.4625)       R180
R46      100            0207/10  rcl      (0.1125 2.625)        R180
R47      3K3            0207/10  rcl      (0.6625 2.0875)       R180
R48      10K            0207/10  rcl      (0.6625 1.9875)       R180
R49      1K2            0207/10  rcl      (0.2125 1.8)          R180
R50      100K           LI10-B   pot      (-0.025 1.275)        R180
R51      470            LI10-B   pot      (0.425 1.2625)        R180
R52      3K3            0207/10  rcl      (0.1 0.95)            R180
R53      10K            P642     ptc-ntc  (0.4625 0.9125)       R180
R54      6K8            P642     ptc-ntc  (-0.2125 2.4125)      R270
R55      47K            PC16S    piher2   (3.7875 0.7125)       R0
R56                     P642     ptc-ntc  (2.1375 3.7875)       R0
R57                     P642     ptc-ntc  (2.3625 3.7875)       R180
R58      0              0207/10  rcl      (1.95 2.1375)         R90
R59      0              0207/12  rcl      (1.8375 2.375)        R90
R60      10             0207/10  rcl      (0.6 2.275)           R0
T1       IRFP360        TO247BV  transistor-power (2.8125 3.8875)       R0
T2       IRFP360        TO247BV  transistor-power (3.9375 3.8875)       R0
T3       IRFP360        TO247BV  transistor-power (0.5625 3.8875)       R0
T4       IRFP360        TO247BV  transistor-power (1.6875 3.8875)       R0
T5       IRF540         TO220BV  transistor-power (2.8125 3.8875)       R0
T6       IRF540         TO220BV  transistor-power (3.9375 3.8875)       R0
T7       IRF540         TO220BV  transistor-power (0.5625 3.8875)       R0
T8       IRF540         TO220BV  transistor-power (1.6875 3.8875)       R0
T9       BF869          TO202    transistor-npn (2.475 1.9875)        R270
T10      BF870          TO202    transistor-pnp (1.525 2.525)         R90
T11      BF870          TO202    transistor-pnp (2.975 2.5375)        R270
T12      BC546B         TO92     transistor-npn (1.0625 0.85)         R180
T13      BC546B         TO92     transistor-npn (1.0625 1.3125)       R180
T14      BC546B         TO92     transistor-npn (1.0625 1.475)        R0
T15      BC546B         TO92     transistor-npn (1.0625 1.7875)       R180
T16      BC556B         TO92     transistor-pnp (1.3125 1.7875)       R0
T17      BC546B         TO92     transistor-npn (-0.25 0.95)          R270
T18      BC546B         TO92     transistor-npn (0.3125 1.9875)       R0
T19      BC546B         TO92     transistor-npn (0.0625 1.9875)       R180
T20      BC556B         TO92     transistor-pnp (0.025 2.2375)        R180
T21      BC556B         TO92     transistor-pnp (0.4625 2.6125)       R180
T22      BC556B         TO92     transistor-pnp (0.4625 2.4125)       R180
TP5      P1-13Y         P1-13Y   testpad  (-0.0375 3)           R90
TP_CC    P1-13Y         P1-13Y   testpad  (2.6875 2.2375)       R90
TP_I+    P1-13Y         P1-13Y   testpad  (0.525 1.8625)        R270
TP_S+    P1-13Y         P1-13Y   testpad  (2.2875 2.2875)       R270
TP_S-    P1-13Y         P1-13Y   testpad  (1.725 2.7625)        R0
TP_T1   P1-13Y         P1-13Y   testpad  (-0.0375 2.8125)      R90
TP_T2   P1-13Y         P1-13Y   testpad  (-0.2875 1.1875)      R180
TP_T1    P1-13Y         P1-13Y   testpad  (2.4125 3.3875)       R90
TP_T2    P1-13Y         P1-13Y   testpad  (3.6125 3.5125)       R0
TP_T3    P1-13Y         P1-13Y   testpad  (0.225 3.475)         R0
TP_T4    P1-13Y         P1-13Y   testpad  (1.3125 3.3875)       R270
TP_Z1    P1-13Y         P1-13Y   testpad  (1.4625 1.875)        R90
